4 members (Otto Skorzeny, Hotrod Lincoln, msmall, Peggy M), 59 guests, and 3 robots.
Topics128,057
Posts1,055,815
#2014 08/18/2004 3:49 AM
Need a way to go from 1/4" inverted flare brake line to 5/16" inverted using a 20" hose. Much like a rear brake hose on most trucks, BUT, needs that bigger size on one end. The other shapes of the ends, no matter, it will not be mounted by the hose at all. It is for the movement between cab and frame on my tilt. It is for the hydraulic clutch. The orig line was 1/4" metal, with hose built on, going to the 5/16" line on frame. I don't know why so big, but sure isn't common. I'm wondering if hydraulic hoses can be made with auto ends? So simple, Yet, so hard! My luck always!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#2015 08/18/2004 4:13 AM
hay Grump! grin must be farm equipt repair places in yer area - we've got an "industrial supply" place here that the farmers all use, that will make up any kinda hydraulic hose ya want - bet that kinda place could do what ya need
#2016 08/18/2004 4:45 AM
Try googleing "aeroquip" and "fittings". You will find catalogs like this online:
http://www.hydraulic-supply.com/PDF/performance/1.pdf
Gord
1954 1/2 ton 235 4 speed
#2017 08/18/2004 1:43 PM
GL the other option is to find a hose that meets the lenght requirement and adapt it to the steel lines. I would think that you could find a hose that was correct on one end and then adapt the other to fit. If I remember tonight when I go home I will pull out my Wagner Hydraulic Buyers guide and see if there are any standard brake hoses that meet your requirement.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#2018 08/18/2004 7:13 PM
GL,
Driving around at work the other day, I saw a custom hose repair truck working on an excavator....looked to me like the van pulled up, made a new hose and installed it to fit on site????
wonder if they could fix ya up if you have any in your area?
#2019 08/18/2004 7:27 PM
Got it! Just found out my local brake supply shop has started making brake hoses. DOT approved, whole works. Cost me about $25, but is Just what I want, flexible like orig, and done!
Wasn't so hard afterall.
G.L. Grumpy's
Old Iron Ranch
