4 members (Bill Hanlon, frogfarmer, 2 invisible), 346 guests, and 5 robots.
Topics128,156
Posts1,057,019
Members48,460
#201311 02/17/2006 12:48 AM
Anyone know where to get or if they have one they don't need. I am looking for the door handle that has lock in the handle. My doors do not have have the hole for the lock and I would love to keep it that way but be able to lock it I need to find a door handle with a lock in it. I have been told they don't even reproduce them and I would have to get lucky and find one. All help would be great.
On a side note I went by the body shop today and my cab is looking really good and should be coming home soon. Yeah!!!!
Brian
1946 1/2 ton
I'm not addicted I just don't know when to stop
#201312 02/17/2006 1:35 AM
Brian - You must have an early 46. Most 46s don't have the lock in the door handle. You might try looking for 41 door handles. You'll have to get a used one because they are not reproduced. Put an add in the swap meet area I'm sure someone will be able to help out. Don't give up they are out there.
George
#201313 02/17/2006 1:42 AM
I have a door handle off a '39 GMC that has a lock in the handle.. I was gunna use it on my '46 1/2 ton passenger side since it's missing all together.. I don't have a key for it, tho.
#201314 02/17/2006 4:13 AM
Thanks guys the search continues.
Brian
1946 1/2 ton
#201315 02/17/2006 4:16 AM
Your 46 only has a lock for the cab under the right door handle. Inside is a turn button for the left door.
Ben H
#201316 02/17/2006 4:56 AM
Neither door has any lock hole
1946 1/2 ton
#201317 02/17/2006 5:37 AM
Every 46 i've ever seen had the lock in the door.. i've seen some early '41's with a lock in the handle, tho.. maybe somebody in the past put earlier doors on it?
Another question might be.. does the door have a locking mechinesim in it at all?
I don't know for sure.. but was a door lock a standard stock thing, or could it have been an option?
#201318 02/17/2006 8:16 AM
Little horse,
I'm not sure this is what you are looking for but it says it's NOS. I found this while surfing EBAY.
http://cgi.ebay.com/ebaymotors/1939...mQQcategoryZ34204QQitemZ4612847783QQrdZ1
#201319 02/17/2006 4:18 PM
On my '46 Panel I don't have any openings for locks either. In side the door there is a shaft for a inner lock knob but nothing on the outside at all.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
#201320 02/17/2006 8:15 PM
my 46 burb has only lock in the pass door handle and an inside knob to lock the driver door
Jim
#201321 02/17/2006 10:17 PM
Little Horse, the 41 had the lock in the handle on the passenger side door and the 46 has the lock cylinder in the door below the handle. Sounds like you have a 41 passanger door on your 46, no matter they are the same. Are you sure it is a 46 and not a 41?? Sometimes the info on the title and body plates have either been changed or a diffrent title was used. Never the less. No repo locking handles being sold right now that I know of. Might have a good - fair used one, would need rechroming but I don't think that I have a key but those are avil from various vendors. Let me know if you are interested and I will check to see what I have.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#201322 02/18/2006 1:04 AM
46 Chevrolet truck: Anyone have a cure for the sagging outside door handles. Thanks
Ben H
#201323 02/18/2006 1:24 AM
Jed Offline
Bhodgeswbmi2,
I think you'll find you need new springs to correct those sagging door handles. They're available through most of the old truck parts houses.
#201324 02/18/2006 3:59 AM
I am leaning towards changing from the stock latch to a small bear claw style with lock. Then either add a key somehow or use an actuator and remote entry system.
Have you seen the locks for suicide doors? The have a door lock actuator that sends a metal rod through the door and frame like a deadbolt. It could also be tied into a remote entry system. Or you could use a hidden switch like the door poppers.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
#201325 03/02/2006 7:52 AM
Little Horse,
If you are still looking for a handle and lock I found this.
http://cgi.ebay.com/ebaymotors/Chev...mQQcategoryZ10076QQitemZ4616139020QQrdZ1
#201326 03/03/2006 12:32 AM
Truckwhisperer,
Thanks for the heads up. I am specifically looking for a handle with the lock in it. I am going to keep on looking.
1946 1/2 ton
