0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 33 Member | | Member Joined: Dec 2005 Posts: 33 | I need some help to understand the assembly manual I purchased through "Chevy Duty". It dosent appear to be in a particular order or have index. Is that the way they are? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy cribb5170, yes unfortunately that's the way they are. But you can always ask us questions, part of the reason we're here is to help if we can. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | The assembly manual shows how everything is put together. Often the shop guides tell you stuff, but lack enough pictures to explain everything. Then you grab that assembly manual. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | which series? the TF manual starts each section w/ "overview" pictures that refer to section numbers - I'd expect all the manuals to be grouped into Frame, Suspension/Brakes, Cab, Front, Bed, Engine/Driveline - should be roughly in the order they assemble the trucks, tho it'll have the different size models mixed thru
helps if you have a bit of understanding of reading blueprints too
Bill | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The assembly manual takes some getting used to, but it is indexed and in order. At the start of each section (body, chassis, etc) there is a series of pictures indicating the page where each assembly step can be found. Each section has a separate number, which also serves as the prefix for the page number. | | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | Hello, Does anyone know where I can get an assembly drawing for a 1946 1 1/2 ton truck? I am a new guy and don,t know all the good spots. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | check ebay, i just bought a original shop manual, 47-51 for ten bucks, you can also post a "wanted" ad on there( i think ) for what you want. | | |
