2 members (55shaker, Peggy M),
78
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | i have access to a "portable" steam cleaning unit that is used around here to clean grafetti off bricks etc and has been used to knock paint off several things as well. basically it is a power washer using steam instead of water. do you think this could be used on all the underneath stuff to knock off rust, grease dirt etc or will it eventually make things worse since it will have to "drip dry"?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Steam cleaners are very useful for removing years of caked on grease and dirt. You might want to pre-soak the worst with detergent a day or two before cleaning.
As for causing more rust, it will. The problems will show up where the grease was caked on, protecting the metal. I would consider this a first step in restoration, since the bared metal will rust faster.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2005 Posts: 68 Member | | Member Joined: Jun 2005 Posts: 68 | I agree with Fred, you should know Where/How much is rusted, & then from there start the repairs/restorations because ancient dirt hides alot of hidden "ut oh" stuff. | | |
