0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#201058 02/14/2006 8:41 PM
In the old days guys would talk about hi-speed rear ends,,, would this be the same as high gears in a rear end or the opposite,,,say a 2:73 vs a 3:90, or would it be some-thing else........ you guys didn't think I could be serious :DFred
Redryder pix
My Hotrod
#201059 02/14/2006 8:50 PM
I
I Offline
Its Valentines day Fred... Better get your rear in gear grin
I don't know if you can handle a "High speed rear" grin
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#201060 02/14/2006 9:32 PM
Ha--- I can handle all kinds, just cant remember what is what,, once I find out , then I can put my shifter in the right slot.............now answer my question grin
Redryder pix
My Hotrod
#201061 02/14/2006 10:34 PM
Us oldtimers refered to the lower numerical ratio, the 2.73-1 in your example, as a high geared rear end. Hi-speed rear end is the same thing, but creates less confusion due to the fact that younger people think of numerical values when talking about ratios; just the opposite of the oldtimers thinking. I usually state "higher geared (numercally lower)" to indicate my meaning.
#201062 02/16/2006 1:50 AM
Baldy,, thanks for your reply,, I was thinking that was the case but not sure,, you don't hear the term that much, I get confused when I hear taller gears, I assume they are referring to higher numercally number, meaning more ump..........Fred
Redryder pix
My Hotrod
#201063 02/17/2006 2:26 AM
Junior Member
Junior Member
I have a 4:10, which is what I understand to be a low gear.
I can certainly tell it when I touch the gas.
I'm sure when I actually get around to driving it around I'll be able to tell when I hafta start paying for the gas.
davey
