0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | In the old days guys would talk about hi-speed rear ends,,, would this be the same as high gears in a rear end or the opposite,,,say a 2:73 vs a 3:90, or would it be some-thing else........ you guys didn't think I could be serious :DFred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Its Valentines day Fred... Better get your rear in gear I don't know if you can handle a "High speed rear"  | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Ha--- I can handle all kinds, just cant remember what is what,, once I find out , then I can put my shifter in the right slot.............now answer my question  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Us oldtimers refered to the lower numerical ratio, the 2.73-1 in your example, as a high geared rear end. Hi-speed rear end is the same thing, but creates less confusion due to the fact that younger people think of numerical values when talking about ratios; just the opposite of the oldtimers thinking. I usually state "higher geared (numercally lower)" to indicate my meaning. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Baldy,, thanks for your reply,, I was thinking that was the case but not sure,, you don't hear the term that much, I get confused when I hear taller gears, I assume they are referring to higher numercally number, meaning more ump..........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2006 Posts: 104 Junior Member | | Junior Member Joined: Mar 2006 Posts: 104 | I have a 4:10, which is what I understand to be a low gear.
I can certainly tell it when I touch the gas.
I'm sure when I actually get around to driving it around I'll be able to tell when I hafta start paying for the gas.
davey | | |
