8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series), 72 guests, and 7 robots.
Topics128,022
Posts1,055,352
Members48,420
Junior Member
Junior Member
I did a search in the forum but didn't find the answer to this question. Presumably everyone knows this stuff but me.
When I use the floor jack on my 1/2 ton I jack it from the center of the axle to bring my front up, and under the pumpkin for getting the rear off the floor. Are these safe points to lift from? Are there better points to lift from, or am I doing this correctly? I'm always certain to use jackstands for safety.
Rich
Rich,
I use the same jack points; and, I also always use jack stands. The placement of the jackstands is dependent on what I am working on underneath the truck.
Tim
