1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20089 03/25/2004 9:22 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | Hi, I have a question. Does any body know how to replace the tube that supplies oil to the rockers for a 235? I heard that Jim Carters sells a kit but they are slow sending my catalog. I also thought a about bending some tube and brazing it in. what do you guys think???? :confused:
1950 1/2 ton 3 window
#20090 03/25/2004 12:19 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Lou, What's wrong with your supply tube?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#20091 03/25/2004 2:16 PM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | The p.o. broke it! all thats left is a little section attached to it.
#20092 03/25/2004 4:09 PM | Joined: Feb 2004 Posts: 60 Member | | Member Joined: Feb 2004 Posts: 60 | If the base is still there just crimp the top where it starts to curl downward. Thats how mine is and it forces the oil throught the rocker shaft with a higher pressure.
If the feed part that sticks into the head is gone than you're out of luck until you get a replacement.
Mine went a 200'ish miles without the supply of oil to the rocker shaft before I bought it and decided to adjust the rockers. Amazingly it has NO grooves warn into it and some how the valley had plenty of oil (maybe splash from the valves/rods).
They're pretty tough! ~J | | |
