4 members (MickeyP, RoadsScholar, Otto Skorzeny, 1 invisible), 203 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
#20089 03/25/2004 9:22 AM
1 Offline
Hi, I have a question. Does any body know how to replace the tube that supplies oil to the rockers for a 235? I heard that Jim Carters sells a kit but they are slow sending my catalog. I also thought a about bending some tube and brazing it in. what do you guys think???? :confused:
1950 1/2 ton 3 window
#20090 03/25/2004 12:19 PM
Lou,
What's wrong with your supply tube?
Craig
#20091 03/25/2004 2:16 PM
1 Offline
The p.o. broke it! all thats left is a little section attached to it.
#20092 03/25/2004 4:09 PM
If the base is still there just crimp the top where it starts to curl downward. Thats how mine is and it forces the oil throught the rocker shaft with a higher pressure.
If the feed part that sticks into the head is gone than you're out of luck until you get a replacement.
Mine went a 200'ish miles without the supply of oil to the rocker shaft before I bought it and decided to adjust the rockers. Amazingly it has NO grooves warn into it and some how the valley had plenty of oil (maybe splash from the valves/rods).
They're pretty tough!
~J
