3 members (Peggy M, Chip O, TexasJim50), 105 guests, and 1 robot.
Topics128,032
Posts1,055,528
Members48,425
#20054 10/21/2003 2:07 AM
Pal
Offline
Looking (and only looking since my wallet is empty) at improving my top speed and gas milage (1968 C-10, 250 Cid, 4spd, 6-bolt pattern, pulling 2700-2800 RPMs @ 60mph). I believe (not sure) my rearend is geared at 4:10. I talked to Randy's Ring and Pinion up in Seattle who suggested either a 3:72 , or 3:42 but the 3:42 needs a new pumkin. At $900+ for the new upgrade/swap (includes Limited slip) is there a specific donor car I should look for?
35 + years of rollin' steel!
#20055 10/21/2003 4:42 AM
Coils or leafs? Chevys were standard with coils, but leafs were available as an option. Once you have that answer, shop your local junk yards for the rear from a 1/2-ton 67-70 Chevy or GMC that came with a V-8 and automatic.
My '72 with a factory 350/350 setup has 3.42 or something close.
If you can find one with the same spring type you should be able to just bolt and unbolt to install it.
#20056 10/21/2003 1:20 PM
Pal
Offline
Sorry about that. Coils.
#20057 10/21/2003 4:16 PM
If you need another place to look, try the 67-72 parts board . You should be able to find a differential in your area for sale.
Fred
52 3600
69 C-10
#20058 10/21/2003 7:03 PM
I picked up a '67 3.07 rearend from a guy in Portland for $125, but he had the gears put into it a while ago for $550. It's going into my '50, so you can't have it, but there are plenty of them out there, you just have to put the word out.
Paint & Body Shop moderator
#20059 10/22/2003 12:40 AM
Pal
Offline
Thanks 4, just tease me! Seriously, I'll keep my ear to the ground.
