1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | I've been looking for a 54 5 window chev, haven't found one yet. But I did find a 54 (I think) GMC 1/2 ton 5 window pickup.
The body looks identical except the grill. Are the parts for the GMC and Chev interchangable? Does anyone know the big differences? | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Engines are different, chevy engines are shorter and the rear mounts are different. I actually have a 54 GMC 100 w/ a Chevy 261 and SM420, which originally came from the factory with a 248 GMC engine and a hydromatic tranny. The gauge cluster is also different between the Chevy and GMC. A chevy anti-sway bar does not bolt right in to GMC without an adaptor because the front cross member is different. The transmission cross member is different as well. Slash aprons are different. There may be other things different, but those are the ones that come to mind.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Front crossmember is different. Grille and surround are different. Front splash pan is different. Hood is different. Tailgate is stamped GMC. Dashboard, gauges, ashtray, glovebox door and horn button are VERY different. Engine is actually designed for truck use, not a passenger car. Hood ornaments (if installed) are very different.Deluxe GMCs could be ordered without the Nu-view corner windows. GMCs were positive ground, Chebbies negative. Both were 6v systems. Parking and taillights are the same. Front fenders are the same. Bed and rear fenders is the same. Cab sheet metal (other than the dash) is the same. Glass is the same. Seat is the same. Gas tank is the same. Transmission, axles and brakes are all the same. GMCs were produced in far smaller numbers than Chebbies. Knowing that you have a real truck is priceless.  | | | | | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | Basically, if I couldn't find a 5 window chev, could I use a GMC 5 window cab and keep the rest chev?
How hard is it to change a positive ground to a negitive ground system? | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I think there is not a more beautiful truck than a 1954 GMC with a crome grill and surround. You will have something that not many others have. Why ruin a GMC by making it look like a Chevy?
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Canadian G.M.C's had the same 235 engine as the Chevy's; not the long motors as in the U.S. And so engine mounts are the same. As mentioned above there are lots of front end sheetmetal differences. You could use a G.M.C cab on a Chev if it's condition made it worth the transplant. Conversion to 12 volt negative ground isn't a problem. Search the electrical forum for that.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | Thanks guys.
The only reason I would use a gmc cab is because I'm having trouble finding a 5 window chev. I'll have to do some more thinking. The engine I will be putting in is a 1962 261 out of a Gmc stake truck.
Thanks again | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | cujo8, the rear mounts are the same for standard tranny trucks. Your rear cross member is different because it was a hydramatic. Yours unbolts, standards don't.
AlZ, keep it GMC. | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Thanks Cletis, I did not know that.
cujo
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I forgot the knobs - some are different, others are the same as the '54 Chebby but in a grey/almond color. | | |
