7 members (Southerntruck, J Lucas, 49nut, moparguy, ndkid275, Barry Martak, 1 invisible),
80
Mod | | | Forums66 Topics128,133 Posts1,056,398 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 58 | April issue of Classic Trucks magazine( www.classictrucks.com ) starting on page 32. They did an article using Mallory's "Custom-Made" Stovebolt Unilite. You have a new distributor, Wayne's rocker and pushrod cover set and a new coil. The sources are www.malloryperformance.com in Carson City,NV., www.patricksantiquecars.com in Casa Grande,AZ., and www.astrocoil.com in San Jose,CA.. Hope you guys find the links helpful. Dave
1954 custom 1-ton (1 of a kind) | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I read that article and it sounds like a good product....but it may be expensive. anybody know the price range?
I noticed that RF has a small air cleaner on that engine. I can't remember where I read it (probably on Stovebolt) but doesn't the small air cleaner "choke" the carb all the time? 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | Price range on what, the UniLite or the Wayne set? The custom-order Mallory units aren't any more than OTC (over-the-counter) ones, at least that's what I was told. The Astro Coil was a little pricey, but I figured it was worth it for the different look that tied in with the Wayne stuff (also, Mallory backed up the performance of the Astros).
As for the Hellings air cleaner, which is no longer in use (I got a Moon shell-type finned one), it didn't seem to restrict let alone choke the carb any more than the stock one. I drilled out the base bracket with 1/4" holes to help with breathing. The Moon one has an open back exposing the K&N element, and it seems to work good so far, as well.
Dave, thanks for the links! | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I can't find any reference to a Mallory "Custom-made Unilite" in the links Dave provided. Patrick has had a Mallory electronic distributor without vacuum avance in his catalog for a good while. Is this the "Custom-Made" Stovebolt Unilite you guys are referring to?
Wayne Mfg Co had a mallory unilite with vacuum advance in their catalog but they are no longer in business. In fact I sent cash for one but got ripped off when they dropped out of sight.
Does anyone know of a source for a mallory electronic distributor with vacuum advance that will fit 6 cylinder chevy 235 and 261 engines?
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | The magazine provides "sources" at the end of the article but they don't include part numbers. Why not? At the "source" I found this: http://www.malloryperformance.com/P...ID=5265&selection=&minselection= I didn't look very hard but I did not see the "custom" option for the adjustable vacuum advance. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | Originally posted by 46SortaStock: The magazine provides "sources" at the end of the article but they don't include part numbers. Why not?
I didn't look very hard but I did not see the "custom" option for the adjustable vacuum advance. There is NO part number for the custom-order UniLites, that's why. As for why it's been hard to get any info from Mallory, I can't answer that. I listed the source as they requested. My contact there, Mike Golding, said all custom distributors were done from the Carson City location (OG Mallory), and the number listed was to that dept. Also, because there is no part number, nobody else carries it (Patrick only has mech advance). | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | How about this, if Mallory still makes this dist. for the 230/250/292 motor, why not modify that unit for the older motor? Haven't seen a Mallory catalog in a while but my old dusty copy list electronic dist. for 230 motors.
Mallorys numbers, Unilite-4562801/4662801/4762801 | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Seriously, if you guys want a cheaper alternative, you might try a Pertronix electronic ignition conversion kit for the stock distributor. It replaces the points completely, allows you to continue using your stock distributor, and takes about 10 minutes to install. And man does it work great. Reliable and quick starts everytime in any weather.
That's around $79 from Summit Racing...800-230-3030.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Sure do like my Petronix. No worries under the cap. Jim | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I'm still a big fan of converting to HEI using a distributor from a later six, all it takes is grinding or filing off the cast ring on the shaft and then clamping on a new one higher up so the distributor will stick in as far as it needs to. You can pull a distributor and coil from a wrecking yard for close to nothing and the work it takes is simple and not very time consuming. HEI puts out lots of spark too!
