| | | Forums66 Topics128,040 Posts1,055,474 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20034 02/22/2004 2:19 PM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | I have used an oversized oil filter in the past on my 292 this application was from a tractor does anyone on this forum have any info on this subject? | | |
#20035 02/22/2004 4:37 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | The 2qt Chevy filter is Hastings 226 or Wix 51794 - 7.822" high. 1qt = Hastings 224, Wix 51061 - 5.178" high | | |
#20036 02/22/2004 5:07 PM | Joined: Jan 2004 Posts: 41 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 41 | 66/292,
Are you talking about a filter from a Chevy/GMC "tractor" or from a farm-type tractor, such as:
Allis Chalmers Case Farmall **** John Deere Massey Harris, Ferguson McCormick Minneapolis Moline Oliver
Curmudgeon
Let's play together nicely.
#20037 02/22/2004 9:11 PM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | farm type tractor, had an old guru toymaster back in nebraska that gave me the fram # and in my old age I don't remember things like I used to. GOt them from tractor supply. | | |
#20038 02/22/2004 9:16 PM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | chuckthetruck thanks I appreciate I get from reading the forum here and the vast knowledge that is connected to the drivers of fine machinery | | |
#20039 02/23/2004 1:28 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | |
#20040 02/23/2004 12:18 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | They'll both fit a 305, but the taller one may present clearance problems (including ground) depending on the chassis. | | |
#20041 02/24/2004 1:49 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | thanks!do you know the ac delco number? | | |
