2 members (Phak1, TUTS 59), 75 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
Junior Member
Junior Member
I posted earlier on whether my truck was a 1/2 or 3/4 ton since the emblems are missing. When I bought it I was told it was a 1967 3/4. However, the 3rd number in my vin is a 1, which according to cetain web sites indicates it's a 1/2 ton. The axles are both 8 lug. All the pics I see show 6 lugs for c10's and 8 lugs for c20's. Also, the 5th number in my vin is an 8, which would indicate a 1968. However, there are no side marker lights, which indicate a 1967. Any help on what I really have?
It's a 3/4 ton for sure. You're right about the lack of marker lights indicating it's a '67 but I'd go by the vin #. Someone could have bolted a '67 front end on it. As far as the vin indicating it's a 1/2 ton. maybe someone swapped cabs and everything. Who knows? But if you have 8 lugs front and rear, it's a 3/4 ton.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Do you have any pictures? There are some other subtle differences between a 67 and 68.
I think there's a model number/VIN stamped on the frame somewere. (Perhaps on one of the side frame rails.) I've never really looked for mine. It might give you a clue if your cab or body has been swapped out.
I agree, As it sits right now it's a 3/4 ton. Cabs are commonly swapped out on these trucks.
Junior Member
Junior Member
I'll take some pics later and post them. Maybe you can see something i'm missing.
8 lug wheels front and back either mean somebody did some real work swapping out front and rear ends, or that it's a 3/4 ton.
'67 didn't have side marker lights.. some had side marker REFLECTORS, but not lights.
If the VIN dosent match the truck, could have been a cab swap.. or maybe somebody just did a VIN plate swap? For example, they had a good truck with no title, and a bad truck with a title, so they just swapped VIN plates?
Junior Member
Junior Member
If it looks, walks and quakes like a duck--it's a duck right. Despite the VIN, since it looks like a 67 3/4 ton I guess thats how I'll do the paperwork at the DMV. It's a lost title vehicle. Thanks for all the info.
Hogrocket, what ever you do don't give the California DMV any more info on the truck than you have to. It tends to make the process way more difficult than it needs to be. If they don't ask don't tell. Been there done that. :confused: grin
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
