| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 31 Junior Member | | Junior Member Joined: Jan 2006 Posts: 31 | I just bought a 67 for 200.00. It was advertised as a 3/4 ton. It has no emblems so I was wandering how I can really tell if it's a 3/4 ton. Thanks in advance. MM | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If it has 6 lugnuts-1/2, 8 lugnuts-3/4.
Evan
| | | | | Joined: Jul 2001 Posts: 36 Member | | Member Joined: Jul 2001 Posts: 36 | I think the 3rd digit of your vin will tell you.
1=1/2 ton 2=3/4 ton 3=1 ton
Look on the inside of your glovebox door. If the option sticker survives it should be there. Inside the door jamb there is another vin tag. | | | | | Joined: Jan 2006 Posts: 31 Junior Member | | Junior Member Joined: Jan 2006 Posts: 31 | It's got 8 lugnuts however, the 3rd digit in the VIN is a 1. Who's right? | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | | | | Joined: Jul 2001 Posts: 36 Member | | Member Joined: Jul 2001 Posts: 36 | Check out this site. It breaks down the VIN. Looks to me like the third digit of your VIN is your GW. http://www.gmcpauls.com/67-72_chevy.htm It's possible your truck has 3/4 ton chassis stuff on it. Is your truck a Chevy or GMC? A GMC VIN might be different. | | |
