| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19996 11/07/2004 2:28 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | just bought a car with a great paiint job but not much care was taken to be sure the paint was kept from the engine compartment. lots of yellow overspray. any suggestions? Jim | | |
#19997 11/07/2004 4:28 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | See if you have a professional automotive paint supplier in your area. I bet they have some cleaners for that. Laquer thinner might work but I would check with them first.
54 3100 with 235 62 flatbed dump C60 with 261
#19998 11/08/2004 6:22 AM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Not clear of your question here :
If there's overspray on the _engine_ , get some cardboard for masking and foo-foo cans of the color you want the engine , wash it , strip it , mask it and re-paint it in situ , you'll love it when it's all dressed again .
If there's overspray from the engine into the firewall etc. , get some rubbing compound and polish it all off the firewall / body as necessary .
use cheap natural sponges as they work the best and are cheap to boot , old towels from the thrift store so's you don't ruin your good polishing rags...
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#19999 11/11/2004 4:01 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | "strip it" What do you mean? Cleaner or paint stripper? :confused: | | |
#20000 11/11/2004 4:10 AM | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Try some strong household multi-purpose cleaner like 409, etc., and a ScotchBrite scrubbing pad. If you don't get it clean enough to suit you, you'll have the surfaces under the hood scuffed up well enough for a repaint without much more prep work. Jerry
