5 members (HandyAndy, klhansen, Hanks custodian, Hugh63c10, dt235sd), 78 guests, and 1 robot.
Topics128,092
Posts1,056,043
Members48,433
I was givin a timing light with four wires. I have never used one but I assume two wires go to you battery, and one also goes to your spark plug. But where does the other one go?
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
Positive side of your coil?
It probably has a remote start feature. One lead goes to the start terminal of the solenoid. One to pos., one to spark plug, one to spark plug wire.
