8 members (66flea, Southerntruck, Otto Skorzeny, GMCJammer51, Phak1, TGP, DadsFirstPickup, Wayne67vert),
118
Mod | | | Forums66 Topics128,049 Posts1,055,682 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | has any one in here used chassis saver does it work as good as thay say it does ???????
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 |
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jul 2005 Posts: 34 Apprentice | | Apprentice Joined: Jul 2005 Posts: 34 | Hey, I used Chassis Saver on my '42. Great stuff as far as I can tell so far. I only put it on last summer, so I can't speak directly to the durability, but the guy at the paint supply place said he's been using it for years and that it's great. I can tell you that the drips of the stuff that I dropped on cement are still there despite my best efforts to remove them, and probably will be for a long time. The stuff is absolutely rock hard once it cures. -Jon [email protected]
Jon 1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
| | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | I put it on part of my 42 frame as well. I will tell you that I prefer Eastwood's Rust Encapsulator. The Chassis Saver is impossible to remove from your hands once it gets on your hands. It has to be scrapped off. The Rust encapsulator removes easily with wash thinner. Your choice, but if you use the Chassis Saver, make sure you use nitrile gloves to protect your hands. BTW, the cost is about the same for the two products. Good Luck. Long live the 42's! | | |
