| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19930 04/25/2005 12:59 AM | Joined: Mar 2005 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 85 | What kind of trouble am I getting into if I attempt this? Any ideas/advice or sources?
Thanks gang | | |
#19931 04/25/2005 1:49 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Should be a piece of cake in that car. Just gather all the original clutch pedals, bellhousing etc. then go find a good T-5. You should have enough room in that car for the Camaro T-5 (close ratio and stout, shifter at the rear). Most of us truck guys want the S-10 T-5 to make for a better fit in the old GM cabs. Read all the T-5 stuff in the tech section. Start searching Ebay for T-5s as well as local bone yards. | | |
#19932 04/25/2005 6:06 PM | Joined: Mar 2005 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 85 | | | |
