| | | Forums66 Topics128,204 Posts1,057,312 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19914 10/16/2002 6:42 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I was recently given a sm420 tranny. The one with the 4 speed incl. granny. It has a Power Take Off that used to pump hydraulic for a dump truck.
What have others done with this PTO?
Will the whole shebang fit in my 55.1 without cutting anything?
Can I just remove the PTO and cover the hole if I don't want it?
Can I just let it sit there and not use it without a problem?
55 1st Chev.
#19915 10/17/2002 2:44 AM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | you can leave the PTO connected and just plug the hose outlets. Or you can remove the unit, make a blind plate and close the opening. If you have the PTO removed you can put it into a box and mail it to me. I always can use a spare one for my dump truck. | | |
#19916 10/17/2002 2:49 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Main uses were for hydraulic dumps and winches. You can leave it in like Fritz said, or you can take it out and find a cover for it. If you're not going to use it, I'd recommend putting an ad in the swap meet, there is some demand for it. You could probably work out a trade for the cover plate, too.
Fred 52 3600 69 C-10
#19917 10/20/2002 2:24 AM | Joined: Jul 2002 Posts: 17 Member | | Member Joined: Jul 2002 Posts: 17 | | | |
