2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
I was recently given a sm420 tranny. The one with the 4 speed incl. granny. It has a Power Take Off that used to pump hydraulic for a dump truck.
What have others done with this PTO?
Will the whole shebang fit in my 55.1 without cutting anything?
Can I just remove the PTO and cover the hole if I don't want it?
Can I just let it sit there and not use it without a problem?
55 1st Chev.
you can leave the PTO connected and just plug the hose outlets. Or you can remove the unit, make a blind plate and close the opening.
If you have the PTO removed you can put it into a box and mail it to me. I always can use a spare one for my dump truck.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
Main uses were for hydraulic dumps and winches. You can leave it in like Fritz said, or you can take it out and find a cover for it. If you're not going to use it, I'd recommend putting an ad in the swap meet, there is some demand for it. You could probably work out a trade for the cover plate, too. smile
Fred
52 3600
69 C-10
Log Splitter!
