| | | Forums66 Topics128,078 Posts1,055,935 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | I have a gmc 1 ton pick up with a 9ft bed, I just recentally found out it was in fact a 1 ton, now i am wondering if the truck is in a 1950 or 1949, How can you tell the difference? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt!
Is it a Canadian built truck? I don't know how the Canadian serial numbers work, but if its a US serial number you should be able to determine the year from the serial number.
You might get some good GMC specific info at OldGMCtrucks.com.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Gasdude,,,on your raditor,,they have it stamped what year the truck was made..i have a 50 chev...so they stamped it j-50...made in october 1950..yours should say something like that,,if it has original radiator... | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Unless they used a radiator from the previous year, or it was changed to the same brand radiator but with a different year stamp. So that method would probably be little use. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | ALL of the cast iron parts, block, head, gear box etc. should have a date code. Like D 11 9 (with A=Jan, B=Feb etc, 11=day of the month and 9 being the year, like 39 or 49 or 59 etc. You can nail year of mfg. down with this code or get close. Parts cast near the end of the year would be acutally used for next calendar year truck. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Get the serial number from the door post, go from there. | | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | shoot off a few pics of the truck. i would like to see the bed. i keep wondering if the bed on mine is original with the truck, or aftermarket. and it is a 9 foot bed also.  | | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | Thanks, for the info, I will use the truck decal info from the old truck.com. As far as the 9ft bed, the rails and the wood were deteriated, so I removed all of it and put stained cedar, side by side with out the rails and zinc carriaged bolted it to the bed framing, perhaps I will get the rails sometime when I,ve got more loot, but right now theres plenty of other things to do. | | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | demo man, I looked at your truck pic thats a cool truck the condition of yours is simmilar to mine, mine presentally has the front end off for wire wheelwheeling and engine parts clean and paint. The 9-ft bed on mine is with pick up box, where as yours is a flat bed, my suggestions may or may not been the answer. Cheers! | | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | In 48 I think....the gas tank was under the bed, THEN in 50 they got vent windows on the doors. Thus, I think this is how I figured out a few years back that my GMC flat bed is a 49. It has the gas tank behind the seat, and windows on the doors are one piece with NO VENT windows. I found a webiste waaay back taht had the history of these in order, with pictures, with explanations of changes each year. I saved it and then my PC got a virus and as far as I know I don't have it anymore. But that is what I can remember. Good luck.
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | I used the vehicle decal code dycryptor from the oldgmc site and it explained that it is a 1950, and confirmed all other info, now I dont have to guess no more, the motor codes will help but this motor I am sure has been changed at some point, anyways thanks ,all you all! | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | '51 was the first year for vent windows. It was also the last year for drop-down door handles. They're the only AD doors that are really worth anything, being a 1-year-only item. | | |
