7 members (5 Window 9434, FAST55, dt235sd, TUTS 59, Bill Hanlon, Uncles51, 78buckshot), 65 guests, and 0 robots.
Topics128,043
Posts1,055,614
#19884 02/25/2004 6:03 PM
The numbers on the left of the dipstick are G2955
to the right of the dipstick are 3836233 with GM5 stamped underneath. The valve cover has the 2 bolts on top to hold it down which I believe make it a 216, but the Carburator to manifold extension gasket used the 235 instead of the 216 which was too small. Help! I looked at the manual and it shows no sign of those numbers..
1950 3100
1980 "Vette"
2005 Mustang GT
http://community.webshots.com/user/jlr1516
#19885 02/25/2004 6:15 PM
3836233 shows a '55 235 at www.inliners.org . The best way to tell is the lifter covers. If they stop at the head, it's a 235. 216 covers go around the sparkplugs to the top of the head.
Fred
52 3600
69 C-10
#19886 02/25/2004 6:20 PM
Someone tried to disguise a 235 as a 216.
#19887 02/25/2004 6:21 PM
Wow, I just ordered a oil pump for a 216, I guess it wont fit hugh!
1950 3100
1980 "Vette"
2005 Mustang GT
#19888 02/25/2004 6:43 PM
No, it won't fit. I do not know where you ordered it from, but in case you did not know, your local auto parts store carries parts for these engines, often a lot cheaper than the vendors. They just will not be in the computer, the clerk will have to look it up in the books. If you get some snotty-nosed kid, he may not want to, and tell you they do not carry it. You will often get this story at Auto Zone.
#19889 02/25/2004 6:53 PM
jlr,
The Master Parts & Accessories Catalog (up to 1954) gives a casting number of 3835517 for 1941-1949 235 heads and also for 1941-1953 216 heads; 3835908 for 50-52 235; and 3701887, 3701886, 3710359 for other 53/54 235s.
I do not have numbers for 1955 and later 235 heads.
It is possible that someone put adapter bolts in the rocker assembly of a post '54 head so that an earlier valve cover could be used. If that is the case, there would be 4 machine screw holes in the head under the seating edge of the valve cover (these holes are for the '54 and later valve cover hold-down bolts). Are you easily able to lift the valve cover to look for the four machine-screw holes?
If you can lift the valve cover, compare the bolt pattern to those at the following link (sorry about not having casting numbers):
http://www.inliners.org/tech/tech5.html
Tim
#19890 02/25/2004 7:30 PM
The bolts are located on the rocker arm assembly,
If I wanted to change over how would I hold the valve cover down. Is it possible it to be a 216 head.
Thanks for all your help, I did order the pump from a local auto parts and Thanks to you all giving me the quick response I was able to call him and he will have his warehouse ship it asap, and I'll have it 2marrow.
1950 3100
1980 "Vette"
2005 Mustang GT
#19891 02/25/2004 8:06 PM
216 and later full-pressure 235s used different head-bolt patterns. So the 216 head wont fit a 235 block. Are there 4 tapped holes in the top of the head where the valve cover gasket goes? Thats a hallmark of a 235 head, and its how a 235 valvecover is held on. How wide is the fan belt? 216s used a very wide belt like 5/8", '54-'62 235s used a fan belt thats the width of a normal V8 belt, like 3/8" or 7/16" wide.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#19892 02/26/2004 2:58 AM
1953 235 heads, whether from a splash or full pressure engine are the same as 54-62 heads but are not drilled with the four bolts as they used the 216 style valve cover.
The 5/8" belt was used through 1952 then it went to 3/8", except for 261.
My Blog
