| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 1 Junior Member | | Junior Member Joined: Jan 2006 Posts: 1 | What is the best way to lower a 1962 3/4 ton Chevy PU | | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Depends on what you mean by "best". Cheapest? Lowest? The one that rides the best?
Probably in your case you will need to use drop springs. Use the ones for a 1/2 ton. Yes, they will fit. You will lose a lot of load capacity. There are plenty of places that carry them. Performance Suspension Technology, Performance Suspension Components and Just Suspension carry them. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Didn't the 62 1/2 ton use torsion bars?
Evan
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | if it has torsion bars you lower it with the adjuster screws.you can also get drop spindles. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | on my 61 i lowered the front by cranking down my torsion bars, i have heard that this is not the best way, but it still drives straight, camber is ok, and it was FREE! for the rear i plan on purchasing 2"-3" drop coils. once i have the truck lowered i am going to purchase new shocks for it, and call the suspension done for now. someday when i have more money i will buy the appropriate torsion bar knuckles that lower the front end, but those are expensive and beyond my abilities now. the front end looks good the way it is, i kind of like the raked look that i have right now but i want to get new coild for two reason, one being ride height and the other being ride quality. the new shocks are also needed for ride quality. I would like to bag it someday but that is also beyond my abilties and budget right now. I am working on a post-college, pre-career budget right now so i am mostly spending money keeping it on the road and maintained. good luck friend.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
