3 members (MNSmith, Otto Skorzeny, 1 invisible),
155
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Hello all, I got my 235 running rough but running and my question is, In order for it to run the advance is all the way against the block. Am I a tooth off, What do you suggest? Thanks Brian
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brian,
You are correct...at least a tooth off. Draw a picture of the rotation of the part that move and the part that doesn't move...it will become clear which way you have to reposition the distributor drive gear.
Pull the distributor slightly out and click, click it back one or two teeth. I think if you pull it out JUST far enough to clear the cam gear, it will still be engaged in the oil pump, and as you rotate it backward, the pump will follow.
Stuart | | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | atomarc,
Thanks I am going to give it a shot today and will let you know what happens tonight. I tried just moving the plug wires on the cap but only got a really loud backfire. no muffler yet. thanks again
| | | | | Joined: Jan 2002 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 25 | where did you get a HEI setup for this engine? And will it work in a 55 engine?
Kael | | |
