0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#198469 01/16/2006 5:43 PM
Hello all, I got my 235 running rough but running and my question is, In order for it to run the advance is all the way against the block. Am I a tooth off, What do you suggest?
Brian
1946 1/2 ton
I'm not addicted I just don't know when to stop
#198470 01/16/2006 5:58 PM
Brian,
You are correct...at least a tooth off. Draw a picture of the rotation of the part that move and the part that doesn't move...it will become clear which way you have to reposition the distributor drive gear.
Pull the distributor slightly out and click, click it back one or two teeth. I think if you pull it out JUST far enough to clear the cam gear, it will still be engaged in the oil pump, and as you rotate it backward, the pump will follow.
Stuart
#198471 01/16/2006 7:50 PM
atomarc,
Thanks I am going to give it a shot today and will let you know what happens tonight. I tried just moving the plug wires on the cap but only got a really loud backfire. no muffler yet.
thanks again
1946 1/2 ton
#198472 01/23/2006 4:10 AM
where did you get a HEI setup for this engine? And will it work in a 55 engine?
Kael
