2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#19808 05/19/2005 12:37 AM
Apprentice
Apprentice
What is semi normal compression for s 216 chevy with about 100,000 miles? Mine averages 100lb for each cyl. Thanks
rrf
#19809 05/19/2005 6:28 AM
50 chevy, The only thing I could find in my manuals is the compression should be 110 psi or greater with each cylinder being within 5 to 10 psi of each other. How does your engine run with the compression at 100 psi, does it smoke or use oil and if not, run it till it dies.
Jamo
Growing old is manditory-Growing up is optionial.
Jamo
http://community.webshots.com/user/erics46
#19810 05/19/2005 1:07 PM
Compression pressure isn't as important as uniformity between cylinders. If you use 3 different compression gauges, it's likely you'll get 3 different readings. I like to see numbers in the 85-to-125 pound range, with no more than 10% variation between cylinders. If you get a major bump in pressure when a little oil is added to the cylinder, you're headed for piston ring problems soon. If a low cylinder doesn't come up when a tablespoon or so of oil is added, the problem is probably valve-related.
