5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#1979 09/13/2002 9:15 PM
Junior Member
Junior Member
What kind of grease / weight do you put in a 53 235? Mine is bone dry. What's it exact purpose; I know distrubting grease to the distributor, but why? Why isn't this done on modern cars? Only curious... if I was a cat, I'd be dead a loooong time ago.
Ohayden
53 Chevy Coupe (Daily Driver)
67 Chevy Camaro (Toy)
68 Chevy Camaro (Weekend Driver)
#1980 09/13/2002 9:29 PM
I have always used wheel bearing grease in mine. It lubes the distridutor shaft that has sprial grooves milled into it to distribute the grease along the shaft. I turn it a couple of times every month and refill mine every tuneup.
Erwin
I know the reality, don’t mess with my fantasy!
Erwin
#1981 09/14/2002 3:21 AM
The reason they aren't on newer vehicles is because people didn't use them on the older vehicles. Designed now not to need manual lube to keep from wearing out the distributor shaft.
Fred
52 3600
69 C-10
