4 members (39Master85, TUTS 59, Forty9, 1 invisible), 67 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
Hello to all, and Happy New Year !
I have decided to move ahead with the 1989 Chevy 2500 project, and will be replacing the Reading enclosed utility body with a regular Chevy fleetside pick-up box.
Which prompts the following question:
Where is a good source for whatever body mount cushions are used between the box and chassis on the '88-'98 pick-ups ?
And, another question:
The cab has one of those lovely "GM fuzzy fabric over foam/moulded headliners", that is drooping.
Is it worth the bother to pull the headliner and try to re-glue the fabric, or is it best to just buy a new headliner ?
Thanks for any help/direction !
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Anonymous
Unregistered
Anonymous
Unregistered
Try Raybucks.com for parts for the "newer" models.
In my area there are some upholstrey shops that will do the headline for about $75 when they run a special. There are also some guys who advertise along the road using bandit signs for headline replacement for even less.
Local autoparts stores outta have those rubber spacer things.
As far as the headliner goes, sometimes you can pull it down.. should be fabric and a backing board. Normally the glue that holds the fabric to the backing board has turned to dust, and it makes a real mess, so try and get it all out before you seperate the rest of the fabric from the backing board.
Once the backing board and fabric are removed from the truck, and the fabric removed from the backing board, clean off all the old dry glue.. which really shouldnt be any more difficult than brushing your had across it.. then get a can of that spray on glue.. spray the backing board, then put the fabric back on. It sets up quick, so have a paint roller with one of those big fluffy rollers on it and roll it all over the fabric to level it out smooth. Give it about an hour to finish setting up, then put it back in the truck.
Of course, if your fabric is jacked up, has stains or the typical cigarette burn holes, you'd be better off just replacing the fabric.. or if the whole DIY spray glue job seems like a little more than you wanna get involved with, several vendors sell replacement headliners.
