1 members (Mike Roache),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 4 Junior Member | | Junior Member Joined: Dec 2003 Posts: 4 | Where can I buy the correct fluid for lever action shocks? or what will work as a substitute? Maybe jack oil or some kind of hydraulic oil? Thanks Dave | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Any non-foaming hydraulic oil will work. I have bottle jack oil in mine. Mike B  | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | 46dave!
I used hydraulic jack oil in mine. It's on a 46 2 ton. They were dry as a bone and I filled them up with that oil. They haven't leaked or seemed to have been harmed by it. They were still working when I put it up for the winter.
Cheers, George | | | | | Joined: Dec 2003 Posts: 4 Junior Member | | Junior Member Joined: Dec 2003 Posts: 4 | jarge--- A 46 2 ton I would like to see that. Restored or not. Thanks for the info.--- 46dave | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Hi 46dave! Thanks for the interest in my truck. You can view it here--- http://www.geocities.com/jarge46/46_Chev.html or check out the gallery in the '46' group. Cheers, George | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Jarge - there is a truck the same as yours out here but it is blue and has a painted grille and a big box on the back. It is used almost daily by a gardner. I'll try to get a photo sometime and email it to you. Bill | | |
