4 members (Nick in Manitou, Gdads51, Bill Hanlon, FAST55), 75 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
Need help to correctly install wiring through firewall. Pictures would be a great help.
hey Bob - I took a pic of my 57 that shows it reasonably correct - the main harness is original factory and feeds to the regulator, down below to the rear, brakes and gas tank, and also to the generator and lights - where the vacuum wiper tube would be is a tube to wipers from a washer I installed, and if you've got the throttle cable, it'd come out there too, with the choke - wire to coil can be there or in the one over by the battery - enuff info? grin
Great, just what I needed.
