| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Despite all the distractions, I managed to get a little done through the holidays. The front sheet metal is on and new king pins and front brakes were installed. Looking more like a truck every day. If I can just keep some momentum going, the end will be in sight. [img] http://www.etv.net/users/jmcneel/s59prgrs5.jpg[/img] \'59 Fleetside page
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Nice work man-the colors are fantastic. You are a talented person. Where did you start and what did you do first? | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Thanks for the kind words. Basicly, just took it completly apart and started with the cab and frame. Only drawback is I need to re-touch a few nicks and scratches put in the new paint during assembly. This is the first time I've torn one down to the frame. Usually I just fix what's broke or worn out and paint them, but this one needed so much it was really the only way to make a nice truck out of it.
Joe McNeel
| | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Joe, Your truck is looking fantastic. Very nice work. Your going to one proud papa!  | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | One fantastic Fleet. Congrats.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | When you finish, take that baby on a road trip to Texas and let us see it in person.
Cliff59 | | | | | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | Great Work!!!!!!!! Good to see you used the correct front V8 motor mounts. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | The old "bird legs" seemed to be the cleanest way to go. I don't loose much sleep over being correct though. The engine was rebuilt from an '82 350 truck engine. I had to grind a small notch in the engine brackets to clear the larger harmonic balancer. I'm going for a nice driver that will look mostly original at a glance, but will have a few subtle touches when you take a closer look.
Joe McNeel
