1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
Junior Member
Junior Member
first off, i promise pictures are coming(prof. photographer i hate digital). plug on side of transmision case(orange wire) has been cut off; where does it go(end up)? wire harnes connecting stoplights connected all wires except single (brown?) wire with very small single plastic connector am i missing onother harness connecting back up to front of truck? mucho thanks in advance.
jcf
3B Offline
Hy Adramelech, Welcome, what transmission are we talking about, standard of some kind or automatic? If its a standard it's probably going to the backup light switch, but that's usually two wires if it's an auto it could be for your kickdown solenoid. Do the lights at the back of the truck work?
6 heaven
6 heaven
If this is a turbo hydramatic 400, that wire is used for the down shift control. A turbo 400 has the vacuum modulator on the passenger side pointing to the side, in the center of the trans body. A turbo 350 has the modulator on the passenger side on the rear of the case.
where is Weimar Tx and welcome to the bolt...
Redryder pix
My Hotrod
Junior Member
Junior Member
it,s an auto(rebuilt) and the plug (single) is in the middle facing drivers side. Need to know what it is so I can look to buy a new one.
jcf
3B Offline
Hy again Adramelech, it sounds like you have a turbo 400, and this wire powers up a downshift solenoid, the other end of the wire goes to a switch under the dash which closes when you push the accelerator pedal to the floor. Hope this helps.
Junior Member
Junior Member
sure does; thanks much.
jcf
Weimar is on U.S. Highway 90 and Interstate Highway 10, eighty-seven miles west of Houston in western Colorado County.
