5 members (bobfake, MNSmith, Wayne67vert, Bill Hanlon, Hotrod Lincoln), 70 guests, and 1 robot.
Topics128,091
Posts1,056,036
Members48,433
#197235 01/04/2006 6:54 PM
Hey guys,
What are the chances of a "350 bored 60 over" running hot?
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
#197236 01/04/2006 7:40 PM
rogpatt,
My uneducated guess is that it is not cubic inch dependent. Either the motor is working too hard, or the cooling system is on vacation.
Stuart
#197237 01/04/2006 7:46 PM
The motor is not in a vehicle (yet)!
A guy I know has it in his shop and mentioned the he would sell it if I was interested. I just dont want a motor that I would have a hard time cooling.
Roger
#197238 01/04/2006 7:53 PM
Roger,
If you know the guy, and you trust his word on the engine, it should be fine. On a properly functioning motor, cooling shouldn't be much of an issue. I wonder if the .060 over was a hot rod attempt or a effort to save a damaged cylinder.
Stuart
#197239 01/04/2006 7:54 PM
I bought a 350 .60 over and have it in my 66 half ton. It does not run hot at all. No hotter than the 283 it replaced.
55 Cabover
#197240 01/04/2006 7:58 PM
Anonymous
Unregistered
Anonymous
Unregistered
Unless you know this guy very well I would walk away from a 350 which has been bored .060. To me that shows that the engine has already had at least two rebuilds or that it really was run hard prior to this to need a .060 bore to clean up the cylinders. I do not know how much the guy is asking but running 350 small blocks can be found almost anywhere and you can always get a rebuilt one from a reputable rebuilder for about $1,000 plus core charge.
As to the cooling issue it would depend on what you going to put it in. A 350 in an Advance design truck could have cooling issues unless the radiator is upgraded and/or fans are added. HD radiators for AD series trucks start at about $350 plus shipping. Task force trucks came with small blocks so their original cooling systems should be able to handle a 350 unless you are really tricking it out. There are several radiator options you can use for a task force series truck as space constraints are not as bad as AD series trucks.
#197241 01/04/2006 8:00 PM
Roger,
As I think about it, cubic inches probably is directly related to BTU's...how much heat a engine will put out. I know what you meant, and as Cabover testified, it's probably a moot point.
Stuart
#197242 01/05/2006 8:44 PM
Thanks for all you info guys.
Roger
#197243 01/05/2006 11:52 PM
dude walk away it has been raged out if it is 60 over
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#197244 01/06/2006 5:51 PM
my dad had a 327 bored .060 over and never ran hot once....probably anything need a good cooling system.
1966 Chevrolet C-10
1971 Chevrolet Camaro RS
1989 Pontiac Bonneville
MY GARAGE...www.dragcitygarage.com
#197245 01/06/2006 6:11 PM
I used to have a 327 bored 90 over, never had a problem.
#197246 01/06/2006 9:27 PM
Are you sure it's a 350? I've heard thar boring a small block 400 .60 over can cause it to run hot because the cylinder walls were already too thin.
If it's actually a 350, and it's only been bored a total of .60 over then it should be fine. But I would still be apprehensive.
My 2 cents.
50-3600-Guy
#197247 01/06/2006 10:20 PM
Many 350s bored 60 over around here.Comes out to about 355,cu.in.I had one in a 31 Fo-d coupe,and it ran just great.In fact it is still running great.You shouldnt have any problem with overheating.
