| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 26 Apprentice | | Apprentice Joined: Dec 2005 Posts: 26 | I'm new to the Stovebolt page but I feel I'm right at home amongst you fellow gear heads. I'm trying to find information on truck frames, 64-66 c-10/20. The info I'm looking for is dimensions between the two series, also short bed and long bed demensions. Does anybody know if they made a c-20 short bed. I'm trying to build a short bed fleetside on a c-20 platform that can tow my trailer. Any suggestive reading material would be appreciated. Hans | | | | | Joined: May 2005 Posts: 33 Member | | Member Joined: May 2005 Posts: 33 | Hello Hans, Chevy never made a 3/4ton in shortbed. I would assume due to the heavy trucks being used for more load capacity. The frame on the 1/2tons is lighter than the 3/4 & 1tons. The easiest way to make a 3/4 short bed is to start with a long bed & have the frame & bed cut down. Along with that comes brake lines & driveshaft. Personally, I would never do that. But then, I'm partial to longbeds & using trucks for work. A lot of people say that there is a stability advantage in a longer truck for towing. There are a lot of 1/2tons out there towing trailers. Just not big ones. I haven't seen any data or had personal experience in comparing the two. But then, I've never heard of anyone converting a 3/4ton to short bed to make a fair comparison. Bottom line: it's your truck. Do what you want. I think that a shorter wheelbase truck with 3/4ton suspension would make for a rough ride. Just my thoughts. Good luck. Scott
Life is good. Keep on playing.
| | | | | Joined: Dec 2005 Posts: 26 Apprentice | | Apprentice Joined: Dec 2005 Posts: 26 | Thanks for the advice. Hans | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen several short-wheel base trucks with 8-lug hubs, and my assumption is that someone swapped axles to get the tougher stuff. They have all been four-wheel-drive.
I don't know why you couldn't swap the 3/4-ton IFS and floater rear under a 1/2-ton frame. I'd bet the IFS would be nearly bolt on, and you could go to a '72 - '87 with disk brakes in the process.
I have a '72 3/4-ton frame with front suspension sitting in the yard. If you want I can take a picture or two of it for you. Rear suspension is gone.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | The long bed truck would make a better towing truck the added lenth will help kept thing from being so rough. (nice ride) have both short and long bed and the long bed is a better ride. the short bed is funner to play with.
You can use the 3/4 ton springs under a short bed truck if they are the same set up coil to coil are leaf to leaf.
Super250six | | |
