2 members (Bill Hanlon, Guitplayer), 96 guests, and 3 robots.
Topics128,035
Posts1,055,441
Members48,422
#196598 12/29/2005 10:52 PM
Hi Folks,
I would like to change the gear ratio in my 41 3/4 ton pickup. I need to do this as inexpensively as possible. I want to go to a 373:1. Any suggestions would be appreciated.
Baldbaron
#196599 12/30/2005 3:41 AM
There is no easy, cheap method. On the 48 and later truck, you can get a 4.10 gear center carrier from a 64-72 10 bolt (HO52) and swap it in. Nothing that I know of is available for the earlier trucks. One solution is to swap the differential, but the newer models are wider.
Fred
52 3600
69 C-10
#196600 12/30/2005 3:23 PM
Fred:
A carrier from a 64-72 10 bolt diff will work on trucks as far back as 1946.
BaldBaron:
Personally, I'd just put a different axle in. Something from a 1953 or newer ('cause brake parts are MUCH easier to find).
As far as that goes, stick one from a 64-72 under there.
#196601 12/31/2005 7:22 AM
btw, Jim Carter's does have the bigger truck pinion kits now. Go to his site and check it out.
#196602 12/31/2005 7:27 AM
#196603 12/31/2005 7:29 AM
one more thing - you can always get the biggest rear tires available (i.e. tallest - 80 series). I did that as well and it helps.
