| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 62 Member | | Member Joined: Dec 2005 Posts: 62 | Hi Folks,
I would like to change the gear ratio in my 41 3/4 ton pickup. I need to do this as inexpensively as possible. I want to go to a 373:1. Any suggestions would be appreciated.
Baldbaron | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There is no easy, cheap method. On the 48 and later truck, you can get a 4.10 gear center carrier from a 64-72 10 bolt (HO52) and swap it in. Nothing that I know of is available for the earlier trucks. One solution is to swap the differential, but the newer models are wider.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Fred:
A carrier from a 64-72 10 bolt diff will work on trucks as far back as 1946.
BaldBaron:
Personally, I'd just put a different axle in. Something from a 1953 or newer ('cause brake parts are MUCH easier to find).
As far as that goes, stick one from a 64-72 under there. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | btw, Jim Carter's does have the bigger truck pinion kits now. Go to his site and check it out. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | one more thing - you can always get the biggest rear tires available (i.e. tallest - 80 series). I did that as well and it helps. | | |
