1 members (Bill Hanlon),
181
Mod | | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | some of you may have noticed from past posts i'm having quite a delima with my steering. my next step is to adjust my tie rods. im looking for some general direction on how to accomplish this. the truck is a 63 c10. the steering turns completely to the left and only 1/3 the way to the right. problem is not with the gearbox. need to adjust the tie rods is all I can imagine to do next. so before rolling around under the truck figuring out through trial and error I thought someone could help with a little knowledge on doing this. Thanks in advance | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Troy, I would suggest that you should drop whatever is connected to your pitman arm, now center you steering box, now put your wheels in straight ahead position. Now you can see just how much you have to adjust to put things back together. If you do not have enough range of adjustment perhaps your pitman arm is not installed correctly, most pitman arms and shafts have at least one master spline, Hope this helps. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Turn your steering to where the inner tie rods are in the same realative position to the frame rails. Then eyeball your front wheels in respect to the rear wheels. Adjust the tie rod sleeves so the wheels both apear to be straight ahead. Than use some system to set the toe-in. It helps to lock the steering wheel while doing this. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
