0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1965 05/27/2004 5:26 AM
This question comes from looking under some trucks in the wrecking yard combined with a little idle thought (a VERY bad idea, I know). Anyway, the T5 on 4WD truckes have a large hole at the output end. Has anyone tried to mutate a torque-tube ball onto the back of one of these trannies?
#1966 05/28/2004 4:33 AM
Junior Member
Junior Member
I probably not help with the torque ball install but maybe with the T5. Are you talking about the opening with the transfer case removed? If you do use the T5 with the transfer case removed you would have no opportunity to use a speedometer. The 4x4 tailhousing does not have a place to install a speedo cable, it is on the transfer case. On the 2wd the tailhousing does include the speedometer connection.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
