6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#196397 12/27/2005 8:12 AM
Well Bolters I have done all I can, I really could use some help. I have a 1959 Apache and I have had a problem with my speedometer acting up.
She started "screaming" last month and now she won't work at all. I lubed the cable 2 or 3 times and it looks ok, but the speedometer will still not work so I guess it is the guage itself? what are my options?
cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#196398 12/27/2005 8:31 AM
did you try driveing it w/ the cable disconnected from the speedo and have the end where you can feel if it actually turns, and smoothly?
if you're convinced it's the speedo, take it out and take a look! grin bit of a drag, but do-able - on the bench you can use a drill to try spinning it [a cable end helps to attach the drill] - if it really is hooped, open'er up and clean'er out - you might find it's just gummed up, which happens
be careful w/ the odometer wheels, they're easy to break - if all else fails, maybe someone can send you another to try, or new ones are available
#196399 12/27/2005 8:41 AM
bill i indeed drove and the cable is OK.
Cliff59
#196400 12/27/2005 8:53 AM
weeeell, time to rip it apart! unfortunately it does require pullin the gauge assembly out the front, which means disconnecting the wiring - can be done from underneath, but the screws that hold the speedo into the cluster are tiny and ya hafta work half blind - I did it after the 4th or 5th time I hadta pull the thing apart! frown
I can take some pics of one I've already got out if ya think it'd help
#196401 12/27/2005 10:10 AM
I will try anything other than having to BUY a new Speedometer. I bet that thing is at least a Sawbuck. I will remove the guage cluster this weekend. the pics may help.
thanks Cliff59
#196402 12/27/2005 2:18 PM
Cliff
I had to take mine apart and found the odometer/ drive gear had a bad spot. It was plastic.I swapped the brass parts from an Ebay gage cluster I bought ~$35 if I remember. It was tedious but do-able. Like was said... the odometer wheels are sensitive I ripped some #'s off but replacement decals are available. Once apart I bet you'll find the trouble.
Still driving Dad's '59
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#196403 12/28/2005 12:18 PM
Johnny Wah and red58,
I will be working on the Speedometer this weekend, so I will try hard to go slow,(pardon the pun) and do it right. My thanks to you for helping. I found a guage cluster today on e-bay but I want to see if cleaning vs. a part or two might fix up my "crying" speedo. If you have any other ideas please let me know. A special thanks to red58 great pics.
Cliff59
#196404 12/29/2005 6:30 AM
Cliff,
I had trouble with mine right after the truck was back on the road after its restoration. After some trial and error, it turned out to be a bad reducer gear that the speedo shop put in to compensate for the new tires. Replaced that and it works great now! Just a thought.
I don't know if you even have one on your trans, but if you do, it is easy to check. Remove it and reconnect the spedo cable. If it works, the reducer is the problem.
Good luck!
Jim Karras
Orange, CA
'59 Chevy Apache 32 Stepside Pickup
E-mail: [email protected]
Internet: www.59apache.com
#196405 12/29/2005 8:10 AM
Hey Jim,
What kind if tires did they put on that they had to put in a reducer gear?
Cliff59
#196406 12/30/2005 6:14 AM
I went with P235/75/R15 Diamond Back Radials. They about 29 inches tall and are just over an inch taller than the last set of tires on the truck, so I insisted that the truck be sent over to this local speedo shop I like and they calibrated the speedo for me using the reducer.
It might be overkill, but I figured this would be the last time I have it at 0001 and wanted to make sure the miles I log and speed I was going on the highway was as close to being right as possible.
I haven't actually checked it yet. However, I do know this place where our local weights and measures inspectors check odometers on taxicabs by driving between two marks that are exactly one mile a part. I figure one day I will take the truck over that way and give it a test.
It will be interesting to see if it is right or if I can loose the little gear. I will let you know when I check it out.
Take care!
Jim Karras
Orange, CA
#196407 12/30/2005 6:26 AM
Jim,
I thought that the old bias tires were about 29 inches as well. What I mean is that when the truck was built only bias tires were used and I think the stance was taller. Now I may be wrong but you really got me to thinking because I just put on some new Coker wide white radials. I need to check the size and see, but I think my new tred is shorter then the origional bias tires.
Cliff59
#196408 12/30/2005 7:05 AM
there won't be a noticeable difference in the speedo/odo readings as long as you don't go from 15's to 16's - in the range of 27-30" will be close enough to factory, which I think is about 28.5" - 205/75R/15 to 225/85R will be about right, but all car sized radials are wider tread [fatter] than original - I got some 700R15LT Yokohama's that have a great look and proper height/width - didn't change the speedo noticeably from the 225/75R I had before
#196409 12/31/2005 6:52 AM
Bill,
That is good to know. The only reason I even went down this road is because of my experience with the ambulance units at work having to go thorugh weights and measure checks every year and so I just automatically thought to do it on my truck. At work, I have the mechanics send out each ambulance over to the speedo shop to check the speedo when we first change from the stock tires to Michelen tires. Anyway, when I take it on the speedo check I will let you know how it checks out. wink
Jim Karras
Orange, CA
#196410 12/31/2005 7:37 AM
cool, that'll be interesting
