1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 11 New Guy | | New Guy Joined: May 2005 Posts: 11 | What are the correct factory type wiper blades for a 1950 1/2 ton? THANKS MUCH. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Welcome to the forum Floyd. Your best bet is to just order them out of a catalog. Jim Carter has them for under $7. plus freight. If you don't have any yet, you should get several catalogs from various dealers. Then you too can drool over all the items you want. Cecil........... | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also get the blades from American Classic, the link is at the top of the page. The originals have the small hooks that go into a hole in the end of the arm. While they look neat, the original blades don't work that well. Tough getting them to stay flat against the glass and make a clean wipe. Here's a picture. [img] http://www.americanclassic.com/images/WW120.GIF[/img]
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Most marine stores have wiper blades and arms that will fit up and work better than the originals. A lot of boat windshields are the same size as stovebolts and have flat glass.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2005 Posts: 11 New Guy | | New Guy Joined: May 2005 Posts: 11 | | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | I knew I had read a tech article somewhere on this some time back but couldn't remember exatly WHERE I read it. Well, it just dawned on me where. Here is a link to the tech section on chevytrucks.org regarding AD windshield wiper blades. http://www.chevytrucks.org/tech/wipers.htm You might want to send e-mail to Andrew Thor at andrewthor@email.msn.com and confirm the year of his truck. I hope this helps.  | | |
