6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#196366 12/26/2005 9:41 PM
I decided to go ahead and adjust my pitman arm myself. I picked up a puller from Autozone and it came off fine. I have the gear box centered with the wheels but now I can get the pitman arm back on. I only pulled the end at the gear box and loosened the end on the draglink. any help here? i just hope i dont have to pull this all off and have it pressed on at a machine shop. any help ASAP would be greatly appreciated.
i have tried:
hitting it with a hammer and putting a jack on it but im not getting an even amout of pressure on it.
#196367 12/26/2005 9:44 PM
alos... i have the cpp power steering kit installed from CPP if that makes a difference
#196368 12/26/2005 10:13 PM
Riding in the Passing Lane
The wide grooves on the arm need to line up with the wide splines on the shaft. It should slip right on. The manual steering pitman arm was smaller than the power steering. If thats the case you will have to get a power str. arm.
1972 Chevy c10 Cheyenne Super
#196369 12/27/2005 12:22 AM
wrenchbuilder... you are a life saver... and i feel dumb!
well... good news and bad news. firstly i was able to get the pitman arm back on with a little bit of common sence from wrenchbuilder. but then after i got it all back together i tested the steering. no luck. seems adjustment is needed in the tie rod ends . well back to the drawing board.
