| | | Forums66 Topics128,028 Posts1,055,413 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | I decided to go ahead and adjust my pitman arm myself. I picked up a puller from Autozone and it came off fine. I have the gear box centered with the wheels but now I can get the pitman arm back on. I only pulled the end at the gear box and loosened the end on the draglink. any help here? i just hope i dont have to pull this all off and have it pressed on at a machine shop. any help ASAP would be greatly appreciated.
i have tried: hitting it with a hammer and putting a jack on it but im not getting an even amout of pressure on it. | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | alos... i have the cpp power steering kit installed from CPP if that makes a difference | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The wide grooves on the arm need to line up with the wide splines on the shaft. It should slip right on. The manual steering pitman arm was smaller than the power steering. If thats the case you will have to get a power str. arm. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | wrenchbuilder... you are a life saver... and i feel dumb!
well... good news and bad news. firstly i was able to get the pitman arm back on with a little bit of common sence from wrenchbuilder. but then after i got it all back together i tested the steering. no luck. seems adjustment is needed in the tie rod ends . well back to the drawing board. | | |
