1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19625 09/12/2003 1:45 AM | Joined: Aug 2003 Posts: 5 Member | | Member Joined: Aug 2003 Posts: 5 | Can someone tell me how to find what year 235 I have in my 52 truck? I also need to I.d. the trans and rear end. Thank You, Gordon | | |
#19626 09/12/2003 3:18 AM | Joined: Apr 2003 Posts: 37 Member | | Member Joined: Apr 2003 Posts: 37 | See if the casting number matches up with one of these: Inliners webpage look for their casting #'s list
BiggerHammer "The key is in knowing where to hit it" | | |
#19627 09/13/2003 2:58 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | The casting numbers are partially hidden by your starter. You need a good flashlight and a cleaning brush in order to see the numbers. I would you to find casted an alpha and 3 numbers ??? Mine is B262 Feb of 62.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
