6 members (frogfarmer, Brian Moore, kades51, baldeagle, Hotrod Lincoln, 1 invisible), 39 guests, and 7 robots.
Topics128,020
Posts1,055,345
Members48,419
#19625 09/12/2003 1:45 AM
Can someone tell me how to find what year 235 I have in my 52 truck? I also need to I.d. the trans and rear end. Thank You, Gordon
#19626 09/12/2003 3:18 AM
See if the casting number matches up with one of these:
Inliners webpage
look for their casting #'s list
BiggerHammer
"The key is in knowing where to hit it"
#19627 09/13/2003 2:58 PM
The casting numbers are partially hidden by your starter. You need a good flashlight and a cleaning brush in order to see the numbers. I would you to find casted an alpha and 3 numbers ??? Mine is B262
Feb of 62.
Craig
