0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19620 06/16/2003 4:24 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I am in the process of rebuilding the front end of my 49 1/2 ton. Got a set of drag link and tie rod replacement balls from one of the vendors. Got all of them pressed out okay and three of the new ones pressed in with no problem. The last one, which is one of the tie rod balls was a very loose fit in the hole. Same size as the one on the other end. Any ideas on a solution other than welding the ball stud in? The shank on the new replacement ball is about .011 smaller than the one I pressed out. Thanks for any input. | | |
