| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | engine number 1952 GM # 3835909 GM 11 What is the engine size? Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Maxx, the number you gave us is the cylinder head casting number for a 50-52 chev. 235 hope this helps | | | | | Joined: Aug 2005 Posts: 23 Member | | Member Joined: Aug 2005 Posts: 23 | Is there a site/generator that tells you what it is?
JJ
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy CHEVYFREAK1822003, Just click on the links at the top of this sight, click on inliners, then click on casting numbers on the left of the page. Hope this helps. | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Thanks Wrench Fetcher you say 235 ci are you on the Island or the or the big rock The machined boss behind the distributor is blank I put a shot of WD40 and a good cleaning it is blank this is a six cylinder single barrel updraft on a Olson Kurb-Side Comet T3-8" GMC chassis PM 152-22, 104" wb, chassis weight, overall length 188.25", GVW with std tires 6200 lbs (7000 with maximum tires) Thanks for all your help Maxx
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Maxx, Firstly my handle is 3B, wrench fetcher is a title they give you here. Secondly I'm in Rosedale on the "big rock" | | |
