| | | Forums66 Topics128,161 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 4 Junior Member | | Junior Member Joined: Dec 2005 Posts: 4 | Its been a month now since I bought my first old truck, a gold and white 1970 1/2 ton. After doing some engine work and a transmission swap, it is drivable, but I would like to convert the front to disc brakes. I've seen many of the kits online, but would like to know if the spindles form a mid 70's Chevy truck would work on my 1970? And of course, I would get some 6-lug rotors to keep the same wheels.
Thanks, Wes. | | | | | Joined: Dec 2005 Posts: 14 Junior Member | | Junior Member Joined: Dec 2005 Posts: 14 | I was told by a local mechanic who has a '66 that you can use parts from a '73-'87 full size truck/van if you change your upper ball joints to match the donor. He got his from a '78 van and took everything from the spindles out. I believe the '70 uses the same frame and suspension as the '64-'66 models. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | My 72 has factory disc brakes, so perhaps you could find a donor to pull bits off of. | | | | | Joined: Dec 2005 Posts: 4 Junior Member | | Junior Member Joined: Dec 2005 Posts: 4 | Thanks WILL64!!!! I was planning on looking in a junk yard for donor parts, and in my area, it would be hard to find a 71 or 72, but trucks from the late 70's are all around. | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | in '71 chevy switched to front disc brakes and also the 1/2 ton 2wds went from 6 lug to 5 lug (would like to know why the changed it) Nate | | |
