| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19579 10/21/2002 6:21 AM | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | HELP, I NEED THE LENTH ON A REAR AXLE. HUB TO HUB ?????? ARE THE 47 TO 55 THE SAME LENTH ????? ARE THE 1/2 TON & 3/4 TON THE SAME.... I DON'T HAVE A REAR END IN MY BONE YARD TO LOOK AT
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | |
#19580 10/21/2002 6:46 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Hey TRUCKMAN, how's it going? You might want to surf over to chevytrucks.org and look in their tech section...they have a nice chart of axle widths listed. If you have a 1/2 ton AD, the usual best bet is a '70-'81 Camaro/Firebird. Not sure about 3/4 ton. Best of luck. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#19581 10/21/2002 8:54 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 3/4 ton's a problem, if that's what you have. The 2nd series and on are 3-1/2" wider than the first series. Using later wheels with a deeper setback makes up for most of this. I'm wanting to say the first series has 56-1/2" on the 3/4 ton, but it's been a long day at work.
Fred 52 3600 69 C-10
#19582 10/21/2002 9:00 PM | | Anonymous Unregistered | | Anonymous Unregistered | A good rearend to use for 1/2 tons are the 60..66 or 67..7? truck rearends as they retain the 6 lugs and are only fractions of an inch wider and have a much broader range of available gear ratios.
I have a 69 rear with 3.08 posi and a 62 with a 3.73 posi - you will have to grind / torch off the trailing link suspension brackets and add spring perches - but E-Brake cable and brake line connections are pretty much identical. | | |
#19583 10/22/2002 2:05 AM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Out to out on my 54 1/2 ton is 62 1/4 inches. | | |
