1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#195447 12/14/2005 11:36 PM
Riding in the Passing Lane
I am detailing a 235 engine on a 54 pass. car. I haven,t put the coil on yet & went ahead & changed the oil. While pouring oil in the valve cover oil fill, I look over & oil is pouring out of the holes that the coil mounts to. Even after 55 years I didn,t know it would do that. frown
1972 Chevy c10 Cheyenne Super
#195448 12/14/2005 11:43 PM
Wrenchbender,
I know you have seen oil filled coils....now you know how to fill them!
Stuart
#195449 12/15/2005 5:13 PM
Every day you don't learn something is a day wasted. I've been in the construction business for 52 years now, but learn new stuff every day. With all the new technology in cars it would be impossible to know enough to keep up without daily learning. Being totally old school all this computer stuff keeps me way behind the kids that have grown up with it.
#195450 12/15/2005 8:58 PM
A couple of weeks ago I removed the throttle pivot from the block in order to buff it up---yup, antifreeze started coming out. Never mind, buff it in place.
A good day is when you can get out of bed, remember your name, learn something--anything during the day, and still remember to go to the bathroom BEFORE going to bed that night.
Word hard, play harder, enjoy life!
#195451 12/16/2005 4:21 AM
thanks guys, i didn't know the coil would leak oil nor did i know the throttle pivot would leak antifreeze. mines broken off and i was gonna try to replace it, but wasn't sure if it was pressed in or screwed in, but at least i know to drain the block now.
thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#195452 12/18/2005 3:39 AM
Wrenchbender,
While reading the factory assembly manual for my truck this evening, I came to the "Ignition Coil & Spark Plug Wire Instruction" page....I had to grin and think of you! There is a assembly note dealing with the coil bracket bolts...it says "dip thread end of bolts in sealing compound before installing coil". Cute! smile
Stuart
#195453 12/19/2005 2:42 AM
Former Workshop Owner
That ain't nothing, I removed the driver's side windshield wiper, and lost all the air out of the left front tire.
Sorry guys, couldn't control myself.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#195454 12/19/2005 2:49 AM
SHOT MAN!! This is better than reading the comics. Keep it up. Who's next??
#195455 12/19/2005 3:19 AM
I too learned something this weekend. I'm putting another sm420 tranny in my truck. I always wondered why mine leaked gear lube in the bottom of the front. I found out that the threaded bottom mounting holes goes all the way through the housing. You gotta put some kind of sealant on the bottom two mounting bolts or it will always leak.
